sparkysavage Posted June 8, 2007 Report Share Posted June 8, 2007 (edited) I have only had the bike for one week ,ridden twice , changed plug ,starts ok when cold .sometimes starts on choke when hot .can anybody give me any clues to the problem. help help thank you peterb the gas gas is brand new 2006 model cleaned out carb and found a bit off muck but problem still persists any other ideas cheers les. Edited June 12, 2007 by sparkysavage Quote Link to comment Share on other sites More sharing options...
peterb Posted June 9, 2007 Report Share Posted June 9, 2007 Hi there, You give us very little to go on. What year bike is it? Is the petrol tank vent fitted correctly, eg: you can blow air into the tank. Is the petrol tap clear of obstructions. Are you running 50:1 fuel/oil ratio (or similar) Have you cleaned out the carb very thoroughly, including removing the emulsion tube, pilot screw, pilot jet and then blowing through the passage ways? If the carb is thoroughly clean, and you still need the choke to start when warm, and the bike is getting on a bit, then the mag side crankshaft oil seal may have failed. Best to provide us with a few more details. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
