Tlr200 Road Elect Removal Can Anyone Help Please ?
sy250
I have a TLR 200 with all the lights etc on. Does anyone know the method please for removing ignition etc and wiring in a kill switch ?
Thanks very much for any advice which would be very gratefully recieved
it should be fairly easy, you can just separate the not wanted bit of the loom at the connectors and you can even keep the original on/off switch, just dont disconect the ignition system.
i found it quite straight forward and took about 15 mins.
