Will A 270 Flywheel Weight Fit A 250 Rev 3?
beta bodger
Flywheel weight should bolt straight on as 270 & 250 have the same ignition system! Dont forget to lock tight bolts as they can come loose! as i found out when it chewed a hole in cover and rattled it nuts off!
