Gas Gas 270 Jtx Contact 1997
philgasgas
this is some info that i had from my 98 tx250
TYRE PRESSURE
FRONT 6PSI
BACK 4 PSI
OIL
PREMIX AT 70:1 (70ML PER 5 LITRES)
WHEEL BEARINGS
6004 2RS
SWINGARM BEARINGS
HK1520 2RS
FORK OIL
7.5 WEIGHT 330ML IN EACH LEG
GEARBOX OIL
10W40, 650ML
RADIATOR
500Ml PURE ANTIFREEZE (CASTROL)
CHAIN TENSION
TIGHTEN CHAIN UNTIL YOU CAN GET ONE FINGER BETWEEN TENSIONER AND FRAME
CARB AIR/FUEL MIXTURE
3.5 TURNS OUT
SPARK PLUG
BP5ES
That's a good list. Best not to use a multi grade oil in the gearbox though, causes clutch drag. Use a straight 10 weight mineral oil only, or an ATF rated to Dexron III, never a synthetic. Re-fill with 700ml.
I always run fuel/oil at 50:1 with a mineral oil, but then I am old fashioned and like to see a 2 stroke smoke a little. My preference for fork oil is 280ml 5 weight in each leg, I guess this is rider dependant.
Bye, PeterB.
  • 13 years later...
