dougie pumpkin Posted July 18, 2007 Report Share Posted July 18, 2007 (edited) Hi, Is there a set method for changing the fork oil on my 07 beta , and what is the best way to go about it ? Edited July 18, 2007 by Dougie Pumpkin Quote Link to comment Share on other sites More sharing options...
amiller Posted July 19, 2007 Report Share Posted July 19, 2007 Didnt your 07 come with a shop manual? Its all laid out for you in there. Aaron Quote Link to comment Share on other sites More sharing options...
dougie pumpkin Posted July 19, 2007 Author Report Share Posted July 19, 2007 Didnt your 07 come with a shop manual? Its all laid out for you in there.Aaron Yes it did, but it is about as useful as a chocolate fireguard.. I ave heard about bleeding and stuf, but there is none of that in there , is they. Quote Link to comment Share on other sites More sharing options...
amiller Posted July 19, 2007 Report Share Posted July 19, 2007 How big are you into wrenching? There are several ways to do it. The most simple way is to take the fork out of the clamp. Loosen the cap first. Pop the top and drain the fluid into a container. Run the slide up and down several times to get maximum fluid out. Measure the amount of fluid you took out then add that much back to the fork with fresh 5 weight. This is not such a good idae if your fork has been leaking but if you are just doing maintiance you will be fine. Aaron Quote Link to comment Share on other sites More sharing options...
