Changing Fork Oil. Help !
dougie pumpkin
How big are you into wrenching? There are several ways to do it. The most simple way is to take the fork out of the clamp. Loosen the cap first. Pop the top and drain the fluid into a container. Run the slide up and down several times to get maximum fluid out. Measure the amount of fluid you took out then add that much back to the fork with fresh 5 weight. This is not such a good idae if your fork has been leaking but if you are just doing maintiance you will be fine.
Aaron
