bowellsyboy Posted July 23, 2007 Report Share Posted July 23, 2007 The front brake disc on my TXT 250cc 1999 has a bit of movement in it. I have just noticed this and thought it had just come loose, however, someone at a trial said it was supposed to be slightly loose and to leave it. Is this correct or should i tighten it so its solid with no movement. Any advice would be really helpful. Quote Link to comment Share on other sites More sharing options...
dschigoda Posted July 23, 2007 Report Share Posted July 23, 2007 The front brake disc on my TXT 250cc 1999 has a bit of movement in it. I have just noticed this and thought it had just come loose, however, someone at a trial said it was supposed to be slightly loose and to leave it. Is this correct or should i tighten it so its solid with no movement. Any advice would be really helpful. I had the same question when I bought my GG 280 Edition 2002. The answer is - it is supposed to be that way - it is call a "floating disk". It is designed that way to allow for better alignment of the disk to the pads, for better braking. ["It's not a problem... it's a feature!] For Trials riding, in very low speed/tight turn situations, you will need to get into the habit of slightly dragging the front brake before you need to brake. That way the "slop" is already taken up. [i learned that from David Chaves at a Ryan Young Trials School (USA).] It has taken me a while to get used to riding that way, though. Dave S. Quote Link to comment Share on other sites More sharing options...
