stoford Posted July 23, 2007 Report Share Posted July 23, 2007 Hi, does anyone know if there is an aftermarket piston kit (ie. Wiseco or ProX) available for the 290 Sherco? Thanks, Stoford. Quote Link to comment Share on other sites More sharing options...
copemech Posted July 24, 2007 Report Share Posted July 24, 2007 Never seen one. The factory pistins are matched, ,to the cyl. in ABCD sizes as I recall. You must know what you need within .01mm. The factory piston should be marked on the top, but you will need to de-carbon it to read it I think! Quote Link to comment Share on other sites More sharing options...
gjbiker Posted July 24, 2007 Report Share Posted July 24, 2007 I just had to pay Quote Link to comment Share on other sites More sharing options...
daggs888 Posted July 24, 2007 Report Share Posted July 24, 2007 I just had to pay Quote Link to comment Share on other sites More sharing options...
daggs888 Posted July 24, 2007 Report Share Posted July 24, 2007 Hi, does anyone know if there is an aftermarket piston kit (ie. Wiseco or ProX) available for the 290 Sherco?Thanks, Stoford. That is cheap man, there is no other aftermarket supplier because there's no market for it ! Thank your lucky stars it isnt a ktm top end rebuild ..... now that would be expensive ! Quote Link to comment Share on other sites More sharing options...
gjbiker Posted July 25, 2007 Report Share Posted July 25, 2007 Hi, does anyone know if there is an aftermarket piston kit (ie. Wiseco or ProX) available for the 290 Sherco?Thanks, Stoford. That is cheap man, there is no other aftermarket supplier because there's no market for it ! Thank your lucky stars it isnt a ktm top end rebuild ..... now that would be expensive ! Quote Link to comment Share on other sites More sharing options...
