Sherco 290 Piston Kit?
stoford
Never seen one. The factory pistins are matched, :rolleyes: ,to the cyl. in ABCD sizes as I recall. You must know what you need within .01mm.
The factory piston should be marked on the top, but you will need to de-carbon it to read it I think! :rolleyes:
  Stoford said:
Hi, does anyone know if there is an aftermarket piston kit (ie. Wiseco or ProX) available for the 290 Sherco?
Thanks, Stoford.
That is cheap man, there is no other aftermarket supplier because there's no market for it !
Thank your lucky stars it isnt a ktm top end rebuild ..... now that would be expensive !
  daggs888 said:
Thanks, Stoford.
