Kinky 4str
jonathan collier
More carb fiddling last night, double checking everything again. I've fitted a little piece of stainless tube inside the rubber connecting tube between airbox and carb (I think this is a Birket tip!) Found the tube in work, a piece of hoover piping was just the right thickness and diameter and appears to be stainless too. Cut off an 1 1/2" and squeezed it in there, holds the circular shape now without the rubber getting kinked. Dunno if this makes any difference but it looks better and I think it was easier to refit the rubber to the carb as you had something to grip :rolleyes:
I've got enough left over for a couple more, if any one want's a bit drop me a line with yer addy, or I'll be going to the Hawkstone round at the w'end and could bring it.
