Txt 200
andy.t
Thanks for the offer Peter but I managed to find an American website www.trialspartsusa.com that had the info,its a 98 model,No351 built.
Dont suppose you know how much play the front disc should have because mine moves up and down on the fixings as well as the side to side float.
Regards Andy.
Hi Andy,
The floating disc set up does tend to get sloppy with time, it's not a bad thing but annoying if the disc is rattling away with the motor idling. Side float is fine. The 98 model has 6 cupped washers that can wear a little and can be replaced, P/N BT27718019. Tap the 8mm headed hex bolts with a drift before losening as they tend to be hard in, re-fit with loctite.
The disc is more likely to be worn, if so, you could get some wahsers turned up to suit.
Bye, PeterB.
