grahamcota Posted August 1, 2007 Report Share Posted August 1, 2007 Hi Everyone I have an oil leak coming from the oil seal on the gear selector shaft.Is it possible to replace this without stripping the engine? Any info would be greatly appreciated. Many Thanks Grahamcota Quote Link to comment Share on other sites More sharing options...
betarick Posted August 9, 2007 Report Share Posted August 9, 2007 Try removing gear lever and gently lever old seal out with a small screwdriver & gently tap new seal in with a socket! Quote Link to comment Share on other sites More sharing options...
grahamcota Posted August 30, 2007 Author Report Share Posted August 30, 2007 Try removing gear lever and gently lever old seal out with a small screwdriver & gently tap new seal in with a socket! Thanks for that Betarick Did just what you said the other day and it is fine regards grahamcota Quote Link to comment Share on other sites More sharing options...
betarick Posted August 30, 2007 Report Share Posted August 30, 2007 No problem mate glad to be some help to someone! Quote Link to comment Share on other sites More sharing options...
