Clutch Bleediing
wrc
Hello,
Ive been attempting to bleed the old clutch fluid from my Scorpa sy250, but cant seem to find a bleed point except for a hexagonal headed
socked attatch to the hydraulic clutch cable on the end nearest to the clutch mechnism. There isnt much room to have a great look as ive not done this beofre and any help would be apprecited.
Thank
WRC
Edited by WRC
Hello,
Thank
WRC
Hello wrc, there is no bleed nipple on the sy,i bled mine at a trial because the sir-clip broke on the slave cylinder pushing the piston out. found new clip put it all back to-gether topped the resivoir up & pumped the lever,while flicking the cabel to get any air to rise to the top,only took 20mins & finished the trial. hope this helps. P.S (pump the lever slow.)
Hello,
Thank
WRC
Hello Slack,
Many thanks for you help.
I have sent you a PM.
Regards
WRC
  • 3 weeks later...
Its probably not a good idea to just bleed the slave. Getting to it is such a hassle that you shoud give irt a rep kit and change the oil at the same time.
To get to it you have to remove; rear mudguard, rear subframe, air box, shocker, muffler, center pot and carb!
