Exhaust Dent Repair Tool?
moulder75
I have dented my exhaust on my Beta Rev3 close to the engine after having an argument with a skip. I was wondering if anyone knew of a tool which can be used to remove the dent. I have been told that you can get a tool which seals both ends so that you can fill the exhaust with compressed air. You can then heat the dented area to remove it etc.
Any advice would be good?
Cheers
Tony
I'm a little skeptical, compressed gasses with oxygen content, heated cherry red with residual two stroke oil, sounds like a recipe for a BIG BANG. I personally weld a piece of eighth welding rod to the offending dent, heat and pull.
Edited by ask greeves
