02 Pro Oil Level
ritcrider
I forgot how many ounces of trans fluid my 02 pro calls for but when I add the recommended amount, the oil is at the bottom of the sight glass. Most bikes are at the center of sight glass when at proper fill level. If I add a little oil until it is centered, it usually drops back down to the bottom of sight glass after riding it. does it blow it out the breather if overfilled slightly? Doesn't appear to be burning any from a faulty seal........no excess smoke or funky smelling exhaust........plug running nice and tan. I know your supposed to change it after every ride anyway.......I'm assuming with so little oil in the gear/clutchcase that some must vaporize and exit out the crank case breather..........
