toesnomore Posted August 15, 2007 Report Share Posted August 15, 2007 HI can any one help. my main bearings have gone i have the hole engin striped down .my plan is to change all the bearings at the same time.how do i get the bearings out that are in the caseings.thay can only come out one way.any ideas Quote Link to comment Share on other sites More sharing options...
betarick Posted August 15, 2007 Report Share Posted August 15, 2007 Place casing on a piece of wood with the main bearings facing down crank side down remove crank seal and gently tap bearings out using a brass drift being carefull not to damage casing! YOU can also use a press for removing them and refiting new ones! i would also get your conrod changed while your there as these wear the same as main bearings! Quote Link to comment Share on other sites More sharing options...
toesnomore Posted August 16, 2007 Author Report Share Posted August 16, 2007 Place casing on a piece of wood with the main bearings facing down crank side down remove crank seal and gently tap bearings out using a brass drift being carefull not to damage casing! YOU can also use a press for removing them and refiting new ones! i would also get your conrod changed while your there as these wear the same as main bearings! thanks betarick Ihave the main bearings out the ones im haveing problems with i the kick start shaft and gear saft bearings which cant bb prest out as the caseing is on the other side. thanks again .any ideas Quote Link to comment Share on other sites More sharing options...
betarick Posted August 16, 2007 Report Share Posted August 16, 2007 Place casing on a piece of wood with the main bearings facing down crank side down remove crank seal and gently tap bearings out using a brass drift being carefull not to damage casing! YOU can also use a press for removing them and refiting new ones! i would also get your conrod changed while your there as these wear the same as main bearings! thanks betarick Ihave the main bearings out the ones im haveing problems with i the kick start shaft and gear saft bearings which cant bb prest out as the caseing is on the other side. thanks again .any ideas I have only changed main crank and gearbox bearings and selecter drum bearings i will have a look at a engine diagram and get back to you! Quote Link to comment Share on other sites More sharing options...
