Beta Techno 1997 Brakes
ramjam
Hi all,
a new member which has a problem.
Could someone advise me on the set up of the front disc?
I had a bolt snap off and drilled it out and removed the remaining bolts to find only 2 bolts had what i would call top hat bushes, should there be 4 and should the brake disc move like a fully floating disc or be stiff for this model?
any pics or feedback would be great,
many thanks
lee
There should be a bush in each hole and 2 round clips to hold bush to disc! I had to replace these on my old techno and with new ones fitted there is still a small amount of play as the discs are floating discs! hope this helps
