scotty Posted August 18, 2007 Report Share Posted August 18, 2007 How do you remove the small allen bolt at the bottom of the fork legs (ie stop it revolving inside?) as i want to strip my forks on my suzuki? thanks in advance! Quote Link to comment Share on other sites More sharing options...
samb Posted August 18, 2007 Report Share Posted August 18, 2007 How do you remove the small allen bolt at the bottom of the fork legs (ie stop it revolving inside?) as i want to strip my forks on my suzuki? thanks in advance! if the fork cap isain left on sometimes the allen bolt can be loosened off . otherwise remove the cap pull out the spring . drain the oil ,down inside on top of the internal damper rod there are 2 flat sides not sure what width this has to be held using a T bar then the allen bolt can be undone . the stanction can be then pulled apart . when reassembling before tightening the bottom bolt . work the fork leg to centralise it on the oil cut off slider otherwise it will stick down when fully compressed . Sam Quote Link to comment Share on other sites More sharing options...
