Striping Front Forks
scotty
How do you remove the small allen bolt at the bottom of the fork legs (ie stop it revolving inside?) as i want to strip my forks on my suzuki?
thanks in advance! ;)
if the fork cap isain left on sometimes the allen bolt can be loosened off . otherwise remove the cap pull out the spring . drain the oil ,down inside on top of the internal damper rod there are 2 flat sides not sure what width this has to be held using a T bar then the allen bolt can be undone . the stanction can be then pulled apart . when reassembling before tightening the bottom bolt . work the fork leg to centralise it on the oil cut off slider otherwise it will stick down when fully compressed .
Sam
