Front Sprocket
andy.t
Hi,fitted my new sprockets to the TX200 1998 bike and have noticed a little play on the front sprocket to shaft,its not much but the question is should there be any and if not what would be the best method to eliminate it.
Regards Andy.
I have always had a bit of slack there with my gasgas sprockets. Generally as long as the new sprocket slides over the shaft without getting hung up on the splines then there is usually not too much worry. I have worn out several sprockets but have never damaged a shaft as of yet.
--Biff
