lewis_gasgas Posted August 22, 2007 Report Share Posted August 22, 2007 When the bikes running , theres a ticking or rattling kind of noise coming from around where the gear selecter is.. this may only happen when warm il try the bike tomorrow when cold see if it does it then. Any idea's what it could be ? gets abit faster when you rev the bike if i remember correctly will check all this tomo hopefully. on my 07 280 too Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 22, 2007 Report Share Posted August 22, 2007 Quite common for the clutch ring gear to pick up a stray piece of metal. Results in a bad tick which could sound like transmission gear or as bad as a rod knock. Inspect the ring gear tooth by tooth, might even need a magnify type glass to find as it bonds to the gear and very hard to see. Hope this is all that`s wrong, good luck. Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted August 27, 2007 Author Report Share Posted August 27, 2007 so open it up and go in from that side of the bike ? and check it from there ? Quote Link to comment Share on other sites More sharing options...
no1 Posted August 28, 2007 Report Share Posted August 28, 2007 Its the kick start idler gear it will have a chip or a dent in it Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 29, 2007 Report Share Posted August 29, 2007 Go in from kick start side. Message from No1 is correct, the metal chip usually comes from the crap kickstart gear and ends up wedged in the primary clutch ring gear. Makes a terrible noise, but nothing is really wrong just annoying. Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted August 29, 2007 Author Report Share Posted August 29, 2007 right so its not drastic then , only started doing it after i dropped it but wasnt onto anything hard, so suppose this is it ? oh and it does do it from cold so all the time basically. Quote Link to comment Share on other sites More sharing options...
lineaway Posted August 30, 2007 Report Share Posted August 30, 2007 If this is it it will do it hot or cold and change with the engine revs. I would still try to fix with searching for it. It would drive me crazy if I was riding it this way. And of course it could be something else entirely being a `pro` engine. Quote Link to comment Share on other sites More sharing options...
fozza321 Posted September 3, 2007 Report Share Posted September 3, 2007 this maybe a stupid suggestion but my bike was making a horrible rattle it just turned out it was the spring on the footpeg, lol Quote Link to comment Share on other sites More sharing options...
lewis_gasgas Posted September 7, 2007 Author Report Share Posted September 7, 2007 haha il check that but im positive that its coming from the engine nothing else. Quote Link to comment Share on other sites More sharing options...
