Fork Seals
andy.t
Hi,if you are doing it on the same bike as mine then its fairly easy because the seals are fitted in the removable cap,I sprayed the clip with WD40 and left overnight and used a small screw driver to ping it out,the seals didn't come out too easy though,will require a hammer and screw driver, but be sure not to dig the screw driver into the surface where the seal fits as it could cause oil to bypass and leak.
Regards Andy.
Edited by Andy.T
