dabs alot Posted May 18, 2004 Report Share Posted May 18, 2004 Has anyone with '04 Pro's messed with the programmable ignition? How do you go about changing it? What changes in performance do you see? Do you have the equipment required to change it yourself or do you have a dealer change it? Quote Link to comment Share on other sites More sharing options...
jtt Posted May 18, 2004 Report Share Posted May 18, 2004 You need the software from GasGas to do it yourself, or your dealer may provide the service (perhaps for a fee to offset the cost of the software). Basically you plug the bike into the laptop and make the changes. You have 4 preset ignition curves to choose from: 1) stock 2004 2) stock 2002 "Pro" 3) old style stock curve, like Edition models, or older JTR, JTX models 4) Raga Indoor curve. Very fast, aggressive curve, with absolutely no rev limiter built in....so be forwarned, major damage could result in a fall on the throttle side Basically you'll see a difference in how the power is delivered....from soft to hard and a few in the middle I haven't had the opportunity to play with it myself yet, but will in the near future I hope. Quote Link to comment Share on other sites More sharing options...
