coxy Posted August 30, 2007 Report Share Posted August 30, 2007 hi im just wondering if anyone could help me at all, i have a 2006 gas gas 250 and it aint revving out, it will start perfectly every time but after about half throttle it wont rev and starts popping and backfiring and stuff, just wondering if anyone hasd had this problem or if anyone could give me some advise as to what to look at etc p.s ive cleaned the carb, air filter is clean etc, new plug in it, fuel and everything is ok anyone help would be appreciated coxy Quote Link to comment Share on other sites More sharing options...
gasgasthermo Posted August 30, 2007 Report Share Posted August 30, 2007 How long has this been goin on ?? will it rev out some times but not others or is it consistant ?? Quote Link to comment Share on other sites More sharing options...
ikb Posted August 30, 2007 Report Share Posted August 30, 2007 My mates 06 Raga was doing something similar after swapping everything off my bike it was the PLUG cap!!! fitted new plug cap then finished the trial at Scott speed!! Quote Link to comment Share on other sites More sharing options...
coxy Posted August 30, 2007 Author Report Share Posted August 30, 2007 its been doing it on sundey and it wont rev out fully at all but it has done it once before but i cleaned the carb out and it run fine again but its defo not carb this time Quote Link to comment Share on other sites More sharing options...
the addict Posted August 30, 2007 Report Share Posted August 30, 2007 Did you blow the carb out with an air line to clean it? if not blow it out as something might be stuck in a jet or passage. Disconnect the kill switch encase your problems there, sometimes they can be the cause of many hours of pulling bikes apart Quote Link to comment Share on other sites More sharing options...
coxy Posted August 30, 2007 Author Report Share Posted August 30, 2007 yeah blown the carb and all the jets out with air line and soaked them in carb cleaner so nowt in there will try that tomorrow thanks! but i would of though if it was the kill switch it wouldn`t run at all?? Quote Link to comment Share on other sites More sharing options...
gasgasthermo Posted August 31, 2007 Report Share Posted August 31, 2007 Its probably the plug cup then, same happened on my bike but it was intermittent would rev out some times but not others but it was on a 125 But tis a cheep and easy thing to check + if its not that then you have got a spare one. Quote Link to comment Share on other sites More sharing options...
motojojo Posted August 31, 2007 Report Share Posted August 31, 2007 Yea, try that plug cap its hard to catch. I would also remove the gas tank valve /filter and clean it. Quote Link to comment Share on other sites More sharing options...
