Clutch On Txt200
wozar
Hi,my bikes been doing that also,to blead the brakes I sucked the brake fluid through from the blead nipple with a syringe,only problem is it still drags abit,when I removed the clutch cover to see what was going on I noticed the pressure plate is moving but not evenly its a bit lop sided, and I think this is causing the drag on my bike,let us know how you get on.
Regards Andy.
Is this a PRO or the older motor.
Most likely the master cylinder seals are passing, or the slave seals are passing. Or, on the older motors, sometimes the ball bearing in the end of the slave piston can get pushed back through the piston and then you are unable to get the travel thet you need on the clutch disengagement. Feels like a dragging clutch. In this case a new slave kit is needed.
Bye, PeterB.
