September 3, 200719 yr Hi. First off the bike has the keihlins carb which i beleive is standard for the 97. It has the standard exhaust and air filter. When i got the bike it had been stood for a long while. It ran fine and ticked over well until i leant it over or went down a steep incline, then it wanted to stall and needed plenty of sluggish throttle to keep it going. I dropped the float height 2mm and that sorted the bogging problem out but i think its still a bit rich. When I stripped the carb to clean it, I noticed that it is fitted with a 102 main jet and the needle has the clip in the top groove instead of the second one down (as per the info i have for the carb). I thought that the best thing to do was revert the carb to standard settings i.e. fit a 100 main jet and move clip to second from top groove. Can anyone tell me the standard float height? and if it sounds like I am on the right track? Also, why would someone have fitted the larger main jet? Is it just someone who didnt know what they were doing or could there have been a reason for it? Thanks for any replies. Marcus
September 4, 200719 yr Author Sorry to have to bump this thread but i'm sure someone out there can tell me the float height for a 97 scorpa 250. Come on guys. dont make me charge you lot with with-holding information!!
