markfitton Posted September 3, 2007 Report Share Posted September 3, 2007 Hi guys Anybody got any advice on which is the best gear oil for my new rev 250, and best place to buy in decent quantaties. 1ltr wont even do two changes. thanks mark Quote Link to comment Share on other sites More sharing options...
the addict Posted September 3, 2007 Report Share Posted September 3, 2007 I use ATF Dexron III, nice and cheap and seems to work better than all the expensive oils I used to use. Quote Link to comment Share on other sites More sharing options...
betarick Posted September 3, 2007 Report Share Posted September 3, 2007 Pj1 clutch tuner for me comes in a 1 litre bottle thats 2 changes! the gearbox only as 500ml of oil in it! Quote Link to comment Share on other sites More sharing options...
markfitton Posted September 3, 2007 Author Report Share Posted September 3, 2007 550 ml in mine how much are you paying for these mark Quote Link to comment Share on other sites More sharing options...
the addict Posted September 3, 2007 Report Share Posted September 3, 2007 12 quid should get you 5 litres of ATF, pretty sure i used to put 550ml in mine as well Mark, bit more for clutch strip down oil change though. The ATF makes the clutch abit quicker, not much but i liked it like that, had no problems using it in my Rev3 for over a year and now using it in the Caby with no problems. I do change it every 20 hours though roughly Quote Link to comment Share on other sites More sharing options...
the addict Posted September 3, 2007 Report Share Posted September 3, 2007 Just checked on lampkins web site and the 06 says 500ml of oil in the clutch so apologies to betarick, pretty sure the handbook said 550 though, Doesnt say info on the 07 though so might be different Quote Link to comment Share on other sites More sharing options...
kinell Posted September 3, 2007 Report Share Posted September 3, 2007 Just checked on lampkins web site and the 06 says 500ml of oil in the clutch so apologies to betarick, pretty sure the handbook said 550 though, Doesnt say info on the 07 though so might be different I think they take 550 from new, 500 comes out when you drop the oil so 50 must stay in unless the cases are split? Quote Link to comment Share on other sites More sharing options...
slapshot 3 Posted September 3, 2007 Report Share Posted September 3, 2007 Just checked on lampkins web site and the 06 says 500ml of oil in the clutch so apologies to betarick, pretty sure the handbook said 550 though, Doesnt say info on the 07 though so might be different I think they take 550 from new, 500 comes out when you drop the oil so 50 must stay in unless the cases are split? As the man says 500 on a change......550 on a split Quote Link to comment Share on other sites More sharing options...
markfitton Posted September 5, 2007 Author Report Share Posted September 5, 2007 Hi guys thanks for yopu input mine's an 07 in the manual its deff 550. A good point though about some staying in the cases. I hadnt thought about that. any way back to the oil at the moment Im using putoline light gear Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted September 6, 2007 Report Share Posted September 6, 2007 Pj1 clutch tuner for me comes in a 1 litre bottle thats 2 changes! the gearbox only as 500ml of oil in it! Hi there Do you use the light clutch tuner oil or the ultra light ? regards gareth Quote Link to comment Share on other sites More sharing options...
