micky Posted September 3, 2007 Report Share Posted September 3, 2007 I am struggling to find the correct torque figure for 320 Majesty head nuts, any ideas? Also, how long should the rear shocks be (original spec.) for a 320 Maj? One last thing, which are the best new shocks for my bike? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
mollygreen Posted September 5, 2007 Report Share Posted September 5, 2007 I am struggling to find the correct torque figure for 320 Majesty head nuts, any ideas? Also, how long should the rear shocks be (original spec.) for a 320 Maj? One last thing, which are the best new shocks for my bike? Thanks in advance. These figures are for a TY250 T/S and are straight out of the CYCLESERVE TY250B servicing manual. I dont know that they can be applied to the Majesty Yams, but I dont see why not, as nuts and bolts are the same whatever! The Cylinder Head Nuts are 8mm and are 2.1 - 2.5 m-kgs. The Cylinder Cap Nuts are 10mm and are 4.2 - 4.5 m-kgs. To convert this to ft-lbs use a rounded off multiplier of 7.233. I hope this will be of some use to you. Quote Link to comment Share on other sites More sharing options...
samb Posted September 11, 2007 Report Share Posted September 11, 2007 the cyclinger head bolts should be set the same as the ty250 , as they were not changed when the barrel was bored out . you could always anneal the copper head gasket ( softening it to make a better seal ) by warming it with a blow lamp then quenching it in cold water . this softens the copper . the standard shocks fitted to the 250 and 320 majestys were girling gas shocks with 13.5" centres . and double springs . Sam Quote Link to comment Share on other sites More sharing options...
micky Posted September 11, 2007 Author Report Share Posted September 11, 2007 Many thanks to you both for the info, My Maj is nearly ready to go after 16 years in bits! I will try and post some pictures if I can work out how to! Quote Link to comment Share on other sites More sharing options...
