Flywheel Weight Removal
veteranhawk
  • 1 month later...
I don't really understand. The flywheel is not needed for the stator to make the electricity, and in this way to appear spark at the plug?
I don't really think that after completely removing the flywheel, the bike will start, because there will be no spark.
Or I am misunderstanding something?
Or you want only to machine some weight off, and to leave the flywheel on the bike?
Edited by fkrisztian
In the UK the Beta has an aditional bolted on weight (for the mud I guess) so he is only talking about removing this weight. I know at least one TC member that has a selection of machined down ones he swaps between depending on ride location.
Personally whenever I get on a bike with the weight on I end up 20-30 metres further than I want to be due to the roll on effect at the top of a climb etc. Obviously this can be very amusing for bystanders but not so for the bike owner :D
Take it off give it a go, try it with both types of throttle tube. A very cheap and easy way to get your bike feeling just how you like it. Be warned though give each and every combination a good months trial before writing it off as they all take a while to get used too.
