adampool Posted September 17, 2007 Report Share Posted September 17, 2007 Following on from earlier queries about gear oil, a few more, simply 'cause the bike is new to me and I dont have a manual!! I assume that there are only two plugs relevent to the gear oil, the large plug with the allen key connection on the top right of the gearbox for filling the oil, and the small plug on the bottom left for draining the oil. I saw from an earlier post that the capacity for a 250 Sherco is 450cc. My bike is the Sherco 290, so I assume we can assume the same capacity. However, is the correct practice to drain the oil completely (good plan anyway) and then fill this volume, or do you fill until the oil is just at the level of the filling hole? Any help appreciated. Oh and does anyone have a maintenance manual they would like to share!! Electronic copy would be great!!! Ta Quote Link to comment Share on other sites More sharing options...
teamsteevo Posted September 17, 2007 Report Share Posted September 17, 2007 This should help you, loads of usefull stuff on here. Clicky . The sherco set-up and lubrication guide gives you step by step instructions on how to change the oil. Quote Link to comment Share on other sites More sharing options...
micm Posted September 18, 2007 Report Share Posted September 18, 2007 Shercos don't generally seem to come with a manual just a poster with basic maintenance tips on the back. The amount of gearbox oil for the whole 05 range of bikes (my most recent 'poster') is 450cc. Quote Link to comment Share on other sites More sharing options...
ham2 Posted September 18, 2007 Report Share Posted September 18, 2007 (edited) Following on from earlier queries about gear oil, a few more, simply 'cause the bike is new to me and I dont have a manual!!I assume that there are only two plugs relevent to the gear oil, the large plug with the allen key connection on the top right of the gearbox for filling the oil, and the small plug on the bottom left for draining the oil. I saw from an earlier post that the capacity for a 250 Sherco is 450cc. My bike is the Sherco 290, so I assume we can assume the same capacity. However, is the correct practice to drain the oil completely (good plan anyway) and then fill this volume, or do you fill until the oil is just at the level of the filling hole? Any help appreciated. Oh and does anyone have a maintenance manual they would like to share!! Electronic copy would be great!!! Ta Just to pick the bones from your post:- Tip the bike to the left slightly and drain out the oil till it stops dribbling. 1) Do drain from the lowest allen bolt (watch for the sealing washer) on the sprocket side of the crankcase . 2) Do add the 450cc of oil to the filler hole(large plug with an o-ring seal) on the kick start side of the crankcase. Do not fill up to the level of that hole. That would be way too much. Edited September 18, 2007 by HAM2 Quote Link to comment Share on other sites More sharing options...
adampool Posted September 18, 2007 Author Report Share Posted September 18, 2007 This should help you, loads of usefull stuff on here. Clicky . The sherco set-up and lubrication guide gives you step by step instructions on how to change the oil. Top link!!! Thanks very much!! That should sort it! Ta Quote Link to comment Share on other sites More sharing options...
