Bike Technology
atomant
Not sure how much they would suited to trials though as i beleive you dont get as much torque from them.
From Wikipedia:
Compared to piston engines, the time available for fuel to be injected into a ****el engine is significantly shorter, due to the way the three chambers rotate. The fuel-air mixture cannot be pre-stored as there is no intake valve. This means that to get good performance out of a ****el engine, more complicated fuel injection technologies are required than for regular four-stroke engines. This difference in intake times also causes ****el engines to be more susceptible to pressure loss at low RPM compared to regular piston engines.
And your point is?
Why I think a w ankel engine would be suitable for trials is :-
[1] You can get a large amount of power from a small displacement. An RX8 has a 1300cc engine and pokes out 220BHP (if I remember correctly)
[2] The engine could be quite small
[3] They can also rev very high
[4] They have a considerable smooth power delivery.
I took an RX4 to bits once - amazing engines :huh:
  • Replies 31
From Wikipedia:
And your point is?
It would require you to change your riding style i think, when you have an engine which might rev to 20,000rpm, but the weight advantage is certainly there.
