ritcrider Posted September 25, 2007 Report Share Posted September 25, 2007 Any opinions or experiences? A lot of club members run Maxima 927 castor based for pre-mix.....others various synthetic's. I used to run Mobil MX2T in my 280 pro at 80:1 but Mobil has discontinued that oil. Just wondering what are the advantages (if any) to running castor based.......I do like the smell of bean oil. Quote Link to comment Share on other sites More sharing options...
d. sileo Posted September 25, 2007 Report Share Posted September 25, 2007 Smells good , tastes great.......Good quality 2 stroke oil, is good quality 2 stroke oil.......both variations are ok for the modern trails engines.......I run ELF at 100 to 1 with NO problems in the last ten years.... in summary , any good qaulity oil will work fine in the modern 2 stroke engine producted these days...... I prefer a full synthic for its engineered chemical properties.....my 2 cents....D Quote Link to comment Share on other sites More sharing options...
madcr500 Posted September 25, 2007 Report Share Posted September 25, 2007 I swear by silkolene comp-2 Synthetic. I run it in my CR500 motard (at about 35-1)and have done for about 7 years. My mate runs the same oil, but in injector form, in his KH750's (he mixes a little in with his fuel too). He built a 750 that dyno'd at 103bhp at crank. he ran it for about 30k miles and then took the engine out and stored it for about 2 years. When he stripped it down not only could you still see the crosshatch on the bores but when i wiped my finger down the bore it was still coated with silkolene from when he last ran the motor. I know there are newer oils out there but i think it will take a lot to make me change from it. Quote Link to comment Share on other sites More sharing options...
overthehill Posted September 26, 2007 Report Share Posted September 26, 2007 a top tip to make gardening slightly more enjoyable is to put some castrol'R' in the lawnmower petrol (even a 4t) then you can cut the TT course in the lawn and go round in ever decreasing TT circles sorry - back to the original question - i cant tell the difference whatever oil i use in the trials bike. I did by mistake use some superunleaded petrol with octane booster that i use for my classic bike once - thought i was on a new bike I also know someone that tried their Mont on diesel as well - that doesnt work though. - eh Jeff? Quote Link to comment Share on other sites More sharing options...
dfwilson Posted September 27, 2007 Report Share Posted September 27, 2007 Running a castor based oil makes anyone who is behind you on the loop want to seek you out and kill you. It smells like sh^t and should only be run by serious A**holes who just like to screw with people. If you are a nice person I recommend using Motul 800 at 80:1 to 100:1 or some fully synthetic oil other than strawberry IPONE. Just my humble opinion. DFW Quote Link to comment Share on other sites More sharing options...
madcr500 Posted September 27, 2007 Report Share Posted September 27, 2007 Running a castor based oil makes anyone who is behind you on the loop want to seek you out and kill you. It smells like sh^t and should only be run by serious A**holes who just like to screw with people. If you are a nice person I recommend using Motul 800 at 80:1 to 100:1 or some fully synthetic oil other than strawberry IPONE.Just my humble opinion. DFW I love the smell of castor, reminds me of my yoof. Quote Link to comment Share on other sites More sharing options...
