Cooling Fan
skatty
hi all new to this forum i have a gasgas txt250 2000 model.......... EH well it's for the 15 year old son to play on OH and me :huh:
what i'am looking for is a cooling fan mine seams to have stoped working i have taken it of the bike today and run a twelve volt power supply to it and bu@@er all happening
Has it got to be one of a gasgas or do other ones fit??????????
Or are they fixable???????
I had the same problem when i bought my 1997 250 scorpa. The bloke i rang said they were all the same and the one i fitted was suitable for gas gas and sherco.
I may be wrong, can anyone else confirm?
  • 3 weeks later...
Not 100% sure on the compatability between all models, I think the later PRO fan units run at a higher speed than previous Gas Gas models. The physical mounting should be more or less the same. I have repaired the odd motor, it is a lengthy process, prising open the casings. Usually, vibration and shock from riding trials causes a winding or two to fracture where they are wound over the armature at a very tight angle. You can scrape away the shellac (insulation) and solder up the broken pieces, but, pretty tricky. I would sooner replace the motor these days.
Bye, PeterB.
