jamese.82 Posted October 1, 2007 Report Share Posted October 1, 2007 Just fitted new grips and then tried to fit some bar end plugs.....how do u fit it properly on the throttle side as to not affect throttle operation? i have been scratching my head for too long now and am lost, probably a simple solution but i can't think any more and gonna take them off and buy some new grips again! many thanks in advance, james Quote Link to comment Share on other sites More sharing options...
tombo46 Posted October 1, 2007 Report Share Posted October 1, 2007 I have a Beta But isnt it possible to just slide the throttle in a bit so that the grip isnt catching on the bar end? All the best Tom Quote Link to comment Share on other sites More sharing options...
jamese.82 Posted October 1, 2007 Author Report Share Posted October 1, 2007 (edited) will do that thanks lol knew it would be summin simple.....bit of more and more frequent brain freeze! here is a pic from couple of weeks ago http://i179.photobucket.com/albums/w307/ja...82/IMAG0022.jpg Edited October 1, 2007 by jamese.82 Quote Link to comment Share on other sites More sharing options...
tombo46 Posted October 1, 2007 Report Share Posted October 1, 2007 always best to step back and take a look at it, wish i had thought to do that a while ago.... Id set myself the job of cleaning the front break caliper so needed to pump the pistons out to clean them, id taken the resevoir off the master cylinder and was pumping but the pistons werent coming out, I kept pumping and pumping for ages, i released the adjuster on the lever all the way out too as i thought the master cylinder may not have been letting more fluid in. after a while i realised it was the clutch lever I was pumping.... after cleaning my brakes the correct way I also had to re-adjust the clutch, DOH!! All the best Tom Quote Link to comment Share on other sites More sharing options...
jamese.82 Posted October 2, 2007 Author Report Share Posted October 2, 2007 funny as! i do stuff like that all the time, did the job this morning. had to saw the end off the twist grip tho.....bit unorthodox i think but did the trick! works and looks as it should, see if it's ok after i drop it a few times. many thanks. james Quote Link to comment Share on other sites More sharing options...
