autodoc345 Posted October 2, 2007 Report Share Posted October 2, 2007 (edited) I have recently gotten a 1999 315r, now with winter coming I want to mount the headlight but just see the lower screw hole at the base of the headlight surround, there is a threaded hole higher but I don't see anything on the headlight to attach to. Is there another bracket that I should have? Please let me know if anyone has an idea, thanks Edited October 2, 2007 by autodoc345 Quote Link to comment Share on other sites More sharing options...
rapid roy Posted October 2, 2007 Report Share Posted October 2, 2007 I have recently gotten a 1999 315r, now with winter coming I want to mount the headlight but just see the lower screw hole at the base of the headlight surround, there is a threaded hole higher but I don't see anything on the headlight to attach to. Is there another bracket that I should have? Please let me know if anyone has an idea, thanks one screw on the bottom yoke and a few cable ties at the fork legs should do the trick headlamp height can be ajusted with a screw inside the headlamp housing cheers Quote Link to comment Share on other sites More sharing options...
