Rear Brake Lever
joe87
My rear brake lever suddenly started rubbing on the chain. There was left to right movement on the lever so I changed the bearing and the bush/nut. I refitted the lever but it still had play on it and touched the chain. I was wondering if I was missing a shim on the bush? Any suggestions???
This happened to mine the other week, Didn't know I'd done it but had dinged it on a rock - when I thought back I could remember the culprit!
Took it off, popped in the vice & warmed it up a bit then carefully bent it out by a couple of mm - there's very little clearance between chain & pedal at best of times so even an almost inperceptible bend (couldn't visibly see any on mine) will cause problems.
Hope this helps
Ade
