manxandy Posted October 12, 2007 Report Share Posted October 12, 2007 I am struggling to replace the swinging arm bearings on my 96 techno. I undo the nut but I cannot free the swinging arm bolt, this looks as though it is screwed into the frame, but it will not unscrew. I have looked to see if there are any pinch bolts or similar which would stop the bolt being unscrewed, but I cant see anything. Have I missed something? Or is there a knack to getting this bolt out? I am cautious about using too much force as snapping something or rounding the allen head of the bolt won't help matters. I was told when I bought the bike that the previous owner had done little or no maintanance, so could it just be seized in, although the swinging arm moves freely (a little too freely). Thanks Quote Link to comment Share on other sites More sharing options...
betarick Posted October 12, 2007 Report Share Posted October 12, 2007 Sounds like its siezed in to me! it should just push out the swinging arm bolt! try plenty of wd40 and leaving it to soak in then try turning bolt with a allen key! Quote Link to comment Share on other sites More sharing options...
pete250 Posted October 12, 2007 Report Share Posted October 12, 2007 Hi I ve also got 96 beta. Once the nut is off the spindle should tap out (how ever I would suggest that for the initial taps to leave the nut slighty wound down to prevent damage to the threads and try to turn the allen head on the other side as you tap).The spindle is aluminium so you have to be very carefull and I guess that the lack of maintenance isnt going to help. It is probably seized a) in the housing and to the needle bearings. I would also suggest downloading a parts catalogue for beta (there is a download somewhere on previous threads but for now I cant remember where) Good luck Quote Link to comment Share on other sites More sharing options...
pete250 Posted October 12, 2007 Report Share Posted October 12, 2007 Hi try http://www.trialsport.com.au/beta/documents.htm for your parts manual. If its the one Iam thinking of it will help greatly to any dismantling. Quote Link to comment Share on other sites More sharing options...
manxandy Posted October 14, 2007 Author Report Share Posted October 14, 2007 Thanks to all of you for the info, the bolt doesn't screw into the frame, so lots of WD40 and even more brute force and ignorance (I am good at that bit) and the swinging arm came out. And what a state the bearings were in. Thanks Again Andy Quote Link to comment Share on other sites More sharing options...
betarick Posted October 16, 2007 Report Share Posted October 16, 2007 Make sure linkage bearings are ok while your on with swinging arm bearings! I remember having to change all these on my old 97 techno! Quote Link to comment Share on other sites More sharing options...
charlie prescott Posted October 17, 2007 Report Share Posted October 17, 2007 Hi Guys As stated change all of the bearings while you are at it. they are always in a state. and the more maintenance on these the better. Spray with WD40 every time you wash the bike to displace water. Try your local bearing shop for the bearings, mine came up with them. Regards Charlie. Quote Link to comment Share on other sites More sharing options...
