315r
hooner
hi want to change the gearbox/clutch oil on my 315r 2000, took bash plate thinking there was a drain plug, but no.
do i have to remove the clutch cover and tip it on its side? if so what quantity to put bak in and what is recommended? thanks
The gear box oil filler is behind the banjo bolt for the clutch hydralic line. Vertically above the drain plug. Its a pig to get off. I made special funnel with a hose attached to pour the oil in but the fillers too small. In the end I removed the clutch cover and poured the oil in there with the bike on its side.
Apart from that there nice bikes. I wish I still had mine.
If it helps at all I picked up a set of cheap small plastic funnels from a local hardware shop and used one that fitted in the end of the nozzle from a tube of mastic/sealant with the tapered end of the nozzle into the filler. It was rigid and easy to hold but pour slowly.
  • 2 weeks later...
thanks for the info sorry about the delay in the reply, what quantity of oil does the gearbox take?
