stoksey25 Posted October 15, 2007 Report Share Posted October 15, 2007 could anyone please tell me the best rear shocks available for a 175 and where to get them from as mine are well rubbish thankyou Neil Quote Link to comment Share on other sites More sharing options...
agp244 Posted March 16, 2011 Report Share Posted March 16, 2011 there a quite a number of shocks available for the ty175 as which is best is a hard one to answer as people have their own preference. i personally use be Betor 360mm between centres with 40 pound springs and im very happy with them. others to consider are rockshocks,falcon. whichever shock you go for get the 360mm length these give a little more travel and if you put the top of the forks level with the top yoke you get a little more ground clearance. hope this helps Alan Quote Link to comment Share on other sites More sharing options...
jon v8 Posted March 16, 2011 Report Share Posted March 16, 2011 there a quite a number of shocks available for the ty175 as which is best is a hard one to answer as people have their own preference. i personally use be Betor 360mm between centres with 40 pound springs and im very happy with them. others to consider are rockshocks,falcon. whichever shock you go for get the 360mm length these give a little more travel and if you put the top of the forks level with the top yoke you get a little more ground clearance. hope this helps Alan Are you riding at Emborough ponds on sunday ? Quote Link to comment Share on other sites More sharing options...
feetupfun Posted March 16, 2011 Report Share Posted March 16, 2011 could anyone please tell me the best rear shocks available for a 175 and where to get them from as mine are well rubbish thankyou Neil Sorry to disagree with previous poster but 360mm shocks have same travel as 340mm shocks Also disagree re advisability of sliding fork tubes down to top clamp - it makes the steering feel worse Recommend 340mm shocks and standard position for fork tubes Quote Link to comment Share on other sites More sharing options...
old trials fanatic Posted March 17, 2011 Report Share Posted March 17, 2011 Sorry to disagree with previous poster but 360mm shocks have same travel as 340mm shocks Also disagree re advisability of sliding fork tubes down to top clamp - it makes the steering feel worse Recommend 340mm shocks and standard position for fork tubes however if you want a recommendation then take whatever you see on here as "suggestions" and try them for yourself. Bike set up and that is what we are talking about here is a very personal thing. I have ridden many bikes that to me feel bloody awful and sometimes almost unrideable but the owner thought they were the dogs danglies. So suck it and see. Quote Link to comment Share on other sites More sharing options...
sigwilk Posted January 14, 2012 Report Share Posted January 14, 2012 (edited) however if you want a recommendation then take whatever you see on here as "suggestions" and try them for yourself. Bike set up and that is what we are talking about here is a very personal thing. I have ridden many bikes that to me feel bloody awful and sometimes almost unrideable but the owner thought they were the dogs danglies. So suck it and see. As I won't be riding mine much (bad back) I used cheap ones off eBay - http://motorcyclerestorations.blogspot.com/2011/12/ty175-todays-progress.html.'>http://motorcyclerestorations.blogspot.com/2011/12/ty175-todays-progress.html. For the front, I believe standard is to have the forks 20mm protruding out of yolk. See http://motorcyclerestorations.blogspot.com/2012/01/ty175-brakes-and-forks-update.html.'>http://motorcyclerestorations.blogspot.com/2012/01/ty175-brakes-and-forks-update.html. There's a couple of reference images there too. Regards Simon http://motorcyclerestorations.blogspot.com/ Edited January 14, 2012 by sigwilk Quote Link to comment Share on other sites More sharing options...
