smalley250 Posted October 21, 2007 Report Share Posted October 21, 2007 My txt 300 stopped today on a trial after running rough on bottom end then back fired and stopped. Im not getting any spark at the plug and all connections are good and dry so any ideas. My mates son has a 125 so is it possilbe to swap CDI units on 125 to a 300 to test. Quote Link to comment Share on other sites More sharing options...
coxy Posted October 21, 2007 Report Share Posted October 21, 2007 try the spark plug cap from your sons bike, from what you have said it sounds exactly like mine was and all mine needed was a new plug cap, they seem to be a regular problem on the gassers Quote Link to comment Share on other sites More sharing options...
pandelboy Posted October 21, 2007 Report Share Posted October 21, 2007 check the small black and white earth wire from your cdi plug it might look ok but they can break just inside cdi plug. replace with larger wire. Quote Link to comment Share on other sites More sharing options...
smalley250 Posted October 22, 2007 Author Report Share Posted October 22, 2007 I is the woodrough key that as sheared so simple fix. Thanks for replies Quote Link to comment Share on other sites More sharing options...
peterb Posted October 27, 2007 Report Share Posted October 27, 2007 To stop this from happening again, remove the woodruff key and lap the flywheel and crankshaft tapers together with some very fine grinding paste, can even mix it with Brasso for a finer mix. Bye, PeterB. Quote Link to comment Share on other sites More sharing options...
