Guest stixnstonesbrokemybones Posted October 29, 2007 Report Share Posted October 29, 2007 I have poodled about on my new 250 Rev 3 for a couple of hours and found that the rubber gaurd between the rear tyre and the monoshock has already worn a hole in it. Is this a normal problem, and are there any suggestions for remedy? Quote Link to comment Share on other sites More sharing options...
Guest stixnstonesbrokemybones Posted October 29, 2007 Report Share Posted October 29, 2007 It does happen quick especially when the bike is new... you will find that as your chain wears and you mve the rear wheel back a bit things get better. They are cheap to replace and even cheaper if you grab yourself some reinforced rubber sheet and use yours as a template before it completely rips apart Thanks for the tip. Quote Link to comment Share on other sites More sharing options...
fuma Posted October 30, 2007 Report Share Posted October 30, 2007 Same thing happened on my new bike as well. Quote Link to comment Share on other sites More sharing options...
nick_heane Posted October 30, 2007 Report Share Posted October 30, 2007 You need to buy a half link for the chain, if not it takes about 6 months to stretch and that's a lot of rubber flaps. Quote Link to comment Share on other sites More sharing options...
eddie_lejeune Posted October 30, 2007 Report Share Posted October 30, 2007 Just leave it, i have ridden my new bike for 5 hours on sat and 2 on sunday and there is a hole in it. I never bother to fix this, must say the new carb makes some difference. Quote Link to comment Share on other sites More sharing options...
