Geordies Only
ham2
I do hope you have problems fitting those bearings Wayne
mrs baldilocks is a born and bread mackem, I dread to think where she'll put your bearings.
seals leaking will be the least of your worries !!!
AND
just in , from Mrs Baldilocks, Portsmouth 4 Toon 1 !!
Edited by Baldilocks
I do hope you have problems fitting those bearings Wayne.....
mrs baldilocks is a born and bread mackem, :D
AND
just in , from Mrs Baldilocks, Portsmouth 4 Toon 1 !! :banana2:
Just smacked mesel with a lump hammer trying to shock the clutch-nut off (uncle Albert's false teeth wouldn't hold the clutch basket still :D ).
Off to Steve's first thing tomorrow to use the ratchet gun.
Hope his neighbours like the sound of his compressor...it's a whopper!
Wayne
any success with the clutch basket Wayne ?
gear is all here to do it if your stuck
Clutch Basket 1 Wayne 0 !
Primary gear is quite hard to remove as well
Cheers Glen,
Clutch basket is off (care of Steve),I am taking my time on this..... but not so long that I have forgotten how it all goes back :D:P
Re-start dismantling tonight...I'm guessing that I can hold the flywheel to undo the primary gear nut or will I twist the crank??
Edited by HAM2
