rick Posted June 2, 2004 Report Share Posted June 2, 2004 I drowned by Rev 3 in some fairly deep water this past week. I had to flip the bike over and pump the water out of the cylindar. I also did the following: -took apart the carb -cleaned out the airbox. -removed the right side flywheel cover, dried and sprayed with WD40 -changed the gearbox oil three times, running the bike briefly after each oil change. The last change showed no signs of water. Is there anything I did wrong or something I should do and I haven't? thanks Quote Link to comment Share on other sites More sharing options...
