alan_nc Posted October 31, 2007 Report Share Posted October 31, 2007 Group, I have a Model 92 Sherpa T that has been converted to electronic ignition with the 1 pound flywheel. Great pickup but no idle (fun in Trials). Is there a heavy flywheel that I can put on and keep the electronic ignition? The heavy points flywheel fits fine but the bike will not fire with it on. Thanks Alan Quote Link to comment Share on other sites More sharing options...
woody Posted November 1, 2007 Report Share Posted November 1, 2007 Can't help you as I don't know which electronic ignition you are running, but I'm curious to know which system it is - especially as it uses a 1 pound flywheel. Is that an internal rotor with coils around the outside? Most trials flywheels are about 5 - 6 pounds at a guess for Bultacos, Ossas etc. The only aftermarket electronic ignition I've heard of uses the standard Bult flywheel Quote Link to comment Share on other sites More sharing options...
alan_nc Posted November 2, 2007 Author Report Share Posted November 2, 2007 Woody, It's the femsa ignition with the external flywheel. The 1 pound flywheel is supposed to be off an Alpina 250. Talked to a guy today that has both a 4.5 pound and a 5.1 pound flywheel that I can borrow and see what works. Both are for points bikes so will probably have to go that route. Alan Quote Link to comment Share on other sites More sharing options...
