Rev3 2001
billboat10
hi just had my stator rewound and the bikes still not giving a good spark it starts after 20 or so kicks then wont start again its soaking the plug do you think this is coil or cdi is there a way i can check them also does any one know if a beta techno cid coil pack can be fitted as i have 2 spare ones has any body done this to theres
cheers
Have a look at the spark you get with the plug out and sitting on the engine somewhere - keep it away from the plug hole though as the flame you can get is spectacular. You should see a fat blue spark across the electrodes. If that is the case all should be well and you have trouble somewhere else. Also - check the plug is clean i.e. the centre electrode is white, any fouling on it will give you grief. If unsure, get a new one to try before tearing into anything else.
Cheers,
Stork.
