betarev3 Posted November 2, 2007 Report Share Posted November 2, 2007 Hi - when I start my 05 Rev3 from cold it fires up immediately, but for the first few minutes running it hesitates and sort of misfires when you rev it. There seems to be a definite loss of power and it does not pull cleanly. This is even after leaving it ticking over for a few minutes before riding. however after a couple of minutes just tooling around, this problem disappears and the bike behaves perfectly with loads of power and pulls cleanly all day. I'm sure it didn't do this when I got it, but that was only a couple of months ago and as it's my first bike I may have been mistaken. I have stripped and cleaned the carb but it is still the same, and the air filter is cleaned regularly. Is this normal? and if not - what could it be?. Possibly the reed valve? Any advice appreciated - Laurie. Quote Link to comment Share on other sites More sharing options...
barrybaines Posted November 2, 2007 Report Share Posted November 2, 2007 When I bought the 07 I was advised to start it with the choke on (from cold) knock it off straight away and let it warm up for 10 minutes on tick over. Whenever I do as I was told it all goes well... If I get impatient it is a little rough for a while Quote Link to comment Share on other sites More sharing options...
betarev3 Posted November 3, 2007 Author Report Share Posted November 3, 2007 Thanks folks - looks like a common issue, and more a characteristic of the engine than a fault, so I won't worry about it again. Appreciate the feedback. Quote Link to comment Share on other sites More sharing options...
