muddymike Posted November 7, 2007 Report Share Posted November 7, 2007 HI .Just got a 2001 315r .Can anybody enlighten me on the chain adjustment on it please.Im fitting chain and sprockets and have no clue to the setting.Thank you in advance.Mike Quote Link to comment Share on other sites More sharing options...
randyrat Posted November 9, 2007 Report Share Posted November 9, 2007 Yup...easy one... Slack when bike on side stand should be 1.0 to 1.4 inches, measured at the midway point on the lower chain run (25 to 35mm in french!!!) Take the tensioner spring off first. Axle nut torque is 69Nm or 51 lbft. There you go... Randyrat (I have the owners manual...if you need any more settings drop me a PM)l Quote Link to comment Share on other sites More sharing options...
muddymike Posted November 16, 2007 Author Report Share Posted November 16, 2007 Thank you for that info Randyrat.Will Pm if any more tech info req,cheers Quote Link to comment Share on other sites More sharing options...
sr34 Posted November 17, 2007 Report Share Posted November 17, 2007 Muddymike said: Thank you for that info Randyrat.Will Pm if any more tech info req,cheers here is a link to the manual http://rs166l34.rapidshare.com/files/54556...15R_02_2002.pdf Quote Link to comment Share on other sites More sharing options...
muddymike Posted November 26, 2007 Author Report Share Posted November 26, 2007 Thank you for the link Quote Link to comment Share on other sites More sharing options...
lingo75 Posted June 23, 2008 Report Share Posted June 23, 2008 Thanks for the link to the manual - does any one have one for 1999 315, althought i think they were the same up to 2001 so that would work. Quote Link to comment Share on other sites More sharing options...
tt5th Posted June 23, 2008 Report Share Posted June 23, 2008 (edited) The only real difference from the '99 is the front shocks changed from Paioli to Showa in 2000. Edited June 23, 2008 by tt5th Quote Link to comment Share on other sites More sharing options...
