kman1600 Posted November 10, 2007 Report Share Posted November 10, 2007 Hi, Finally getting around to putting my old Cota 310 back together. Would anyone happen to know the grade of oil I should be using in the gearbox? also how much does the gearbox take? Thanks Tim Quote Link to comment Share on other sites More sharing options...
kman1600 Posted November 10, 2007 Author Report Share Posted November 10, 2007 kman1600 said: Hi,Finally getting around to putting my old Cota 310 back together. Would anyone happen to know the grade of oil I should be using in the gearbox? also how much does the gearbox take? Thanks Tim Hi, Found the answer to my own question in the aircooled monoshock section, hidden behind a question about a Cota 309, looks like I might have her back together sooner rather than later. Tim Quote Link to comment Share on other sites More sharing options...
rockhound Posted November 7, 2014 Report Share Posted November 7, 2014 K man , so what is the amount of oil you put in the case of a montesa 310 cota ? been searching ?? Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted November 11, 2014 Report Share Posted November 11, 2014 750 to 900 cc of SAE 10W30. It's the same for the gearbox and the clutch. Motul Transoil is a good option. Quote Link to comment Share on other sites More sharing options...
