Front Disc
gasgas280
I don't think that one floats.
If it did, and was worn, it would float (shake) more.
As far as I can tell, the biggest advantage of a floating disk is that it does away with the very slight drag that sometimes causes squeaking when the brake isn't applied.
If you don't have it, you're not missing much.
