tyanything Posted November 13, 2007 Report Share Posted November 13, 2007 I need a master cylinder kit for the front brake.I'ts the short straight fitting master cylinder but can only find kits for long straight fitting or short 90 degree fitting one in UK! These are sold here http://www.bvm-moto.co.uk/mcylinders.htm but the only place I can find selling the one I need is sold here http://www.ajpamerica.com/master-cylinders.html in America! Can't seem to find anywhere in the uk.Help? Quote Link to comment Share on other sites More sharing options...
gjbiker Posted November 14, 2007 Report Share Posted November 14, 2007 (edited) If your master cylinder internals look like this ; Repair kit then quote that part number (BT27722208) to BVM and they'll sort you out. Alternatively give Gas Gas UK a call, if they can't help nobody can ???? This should be the correct part No for your bike assuming it's an original brake master? If you reckon it's not standard then go back to the AJP website and browse the repair kits to see if any match your own. Their part numbers (the long ones) are the same as Gas Gas as opposed to the part numbers on the BVM website. Hope this helps ? GJ Edited November 14, 2007 by gjbiker Quote Link to comment Share on other sites More sharing options...
motojojo Posted November 14, 2007 Report Share Posted November 14, 2007 I would find a Nissin(Japanese) It's what the pro's use anyway. I had a Fantic years ago and had trouble with front and back brakes and replaced them with Nissin Master cylinders and never had any trouble after that. Quote Link to comment Share on other sites More sharing options...
tyanything Posted November 14, 2007 Author Report Share Posted November 14, 2007 If your master cylinder internals look like this ; Repair kit then quote that part number (BT27722208) to BVM and they'll sort you out. Alternatively give Gas Gas UK a call, if they can't help nobody can ???? This should be the correct part No for your bike assuming it's an original brake master? If you reckon it's not standard then go back to the AJP website and browse the repair kits to see if any match your own. Their part numbers (the long ones) are the same as Gas Gas as opposed to the part numbers on the BVM website. Hope this helps ? GJ Brilliant,thanks very much....sorted! Quote Link to comment Share on other sites More sharing options...
